PARX
LB, I am trying to locate your rear suspension set up I read in the past, & what for short snow flap are you guys using, thanx to all & MERRY CHRISTMAS
LazyBastard
Boston RX1
Parx, what model Baja are you running? I looks like a 34' or 38' Performance. I run a 302 Boss with 640 HP. I love it. It is a great family boat.
PARX
Thanx LB, also, should I replace the front springs on an 04 before I set no preload or will 04 springs suit, 190 lbs with gear?
Boston RX1, no that is a dream boat off of Baja site, two years ago I sold my 24' & was planning on a 302 Boss, fuel prices sky rocketed & I had second thoughts. I like running Cheasepeke bay & I am not a floater, I like to run, spend the whole weekend on the boat at different marinas. I boated twelve years straight & miss it alot. One day I will probably be back on the water. I thought that was a 302 Boss picture, but you are right, that looks like a 34' or 38'.
LazyBastard
The 04 springs are a little soft, but somewhat suitable. If they bottom too much, put in stiffer ones.
