stingray719
On the "other site" an explanation was issued as per leaks. With this system of rubber hoses on aluminum tubes the aluminum cools and contracts faster then the rubber hose and clamp. That is why you didn't see your sled leak at the dealers or sitting in your garage before the first ride. That is also why several heat cycles need occur and a retighten of clamps should happen. This is supposed to occur on your 300 mile check up on Yamaha if I am reading the check up right?
I believe this as I had this issue on both my turbo and supercharged Phazers. Took several heat cycles to get a good tighten on all the boost hoses where they no longer wanted a tighten.
Thoughts?
Thoughts?
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
- 14 Viper LTX, 10 Turbo Phazer MTX, 08 Phazer, 88 SnoScoot
mine was pissin out fluid well before 300 miles.
RXVIPER
- Mar 4, 2010
- Shelburne ,Ont
- 2014 SR Viper LTX
2003 RX-1
Mine leaked after the first 20 Kms , all better now at 870 Kms . Just put some of my loving care to it, no more leaks.
09nytro
Never had a problem from day one !
But I did get some mud on my snow flap today
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
no problem here
skidooslayer687
- Aug 22, 2013
- Almonte, Ont.
- 2014 Yamaha Sr Viper LTX SE
I had loose clamps and hardware from day one on mine... But that is true about the expansion rates being different. Just wasn't the case on mine.
- Apr 14, 2003
- Hessel, Michigan
Tightened when new, checked again after 270 miles, going to check again after my oil change and post if they were loose or not.
TurboJamie
Thats a BS explaination in our case the clamp was not even in the right part of the barb sticking out of the rad. It was just piss poor workmanship.
