beeze455
vector06 said:beeze455 said:Being a short track, a timbersled setup or an mcat float skid does not make real sense. They both would drop 30 pounds or more on an XTX and MTX, but those skids are not known as the most trail friendly. This would also require you to extend the sled and such.
The skinz seat only loses a lot of weight when you add the under tunnel kit with it. The SDR under tunnel exhaust is a complete kit that would both lose dry and riding weight. You could also fab your own under tunnel exhaust.
The battery option is easy and plan on doing it this year also.
From my reading because I am modding my sled right now too, I would suggest researching removing the foam on the panels, under tunnel exhaust, battery and relocating your tools. After that, you really start paying for items.
Do you mainly trail ride? I ask because some other mods may be better then just focusing on losing weight.
Yes...I only trail ride...
If i only trail rode, I would not worry a ton about weight. I would first get skis with some shaper bars, roest skid plate, trail tank, heated shield and maybe relocate the handlebars.
Nikolai
The YTZ10 battery will drop 7 lbs. Another fairly inexpensive weight loss are RMK Gripper skis if you can find a nice used pair. They're 4 lbs lighter(total) than MTX skis and work better too.
There is ton of weight to be lost, just depends on how deep your pockets are and how creative you want to get.
You should post a link to your project!
NytroZulla
- Nov 19, 2011
What is the part # of the Braile battery?
NytroZulla
- Nov 19, 2011
Is it teh B106 that would fit in the Nytro?
NytroZulla
- Nov 19, 2011
Whoever is putting a Lithium Pro in their sled must be wiping their #*$&@ with $100 bills!
beeze455
NytroZulla said:Whoever is putting a Lithium Pro in their sled must be wiping their #*$&@ with $100 bills!
It is a 3lb pound battery with the same power and is a little over 200 bucks. Yes, I plan on buying one.
Nikolai
Here's a link to the Lithium Pro 12V batteries.
http://lithiumpros.com/products/
What battery are you looking at?
![All Coholic :drink: :drink:](/styles/default/xenforo/smilies/all_coholic.gif)
![Dance 2 LaLaLa LaLaLa](/styles/default/xenforo/smilies/dance_2.gif)
Confused?
Hey how do u guys like Ye xtxs for turny trails ditchbangin and hill climbs or should I go 136 with tipped rails
beeze455
Nikolai said:Here's a link to the Lithium Pro 12V batteries.
I want to go with
http://www.ballisticparts.com/products/ ... 16cell.php
or
http://www.ballisticparts.com/products/ ... 12cell.php
Does that battery require a special charger?
beeze455
Nikolai
beeze455 said:Nikolai said:Here's a link to the Lithium Pro 12V batteries.
I want to go with
or
Looks like the 12 is the way to go. Only 3 lbs and better specs than the factory battery. May have to buy one and try it out.
Smelter
I'm thinking that would be a rough feeling......but if you got the money...wipe away
![Rockon :Rockon: :Rockon:](/styles/default/xenforo/smilies/rockon.gif)
