Hi
When assembling clutches are you using any type of lubricant on any of the moving parts?
dem1000
- Feb 15, 2016
- Jokkmokk
- Sweden
- Side Winder MTX 153 -20
m8000 153 -19
Side Winder BTX 153 LE -17
M6000 153 -17
SR Viper MTX 153 -16 sold
Apex XTX -14 sold
Nytro XTX -11 sold
No.
![](/styles/vip.gif)
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
BIG NO!
![](/styles/TYLifeMember.gif)
BIGGER NO!
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Hi
Designed to be dry. Think about lubricant flinging around at 9,000 rpm's, it would end up on the sheaves and on your belt causing all sorts of problems.
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
If you remove your primary they say to put a little oil on the bolt threads before installing. Other than that everything is dry.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I oiled my primary once and it failed 500 mile later. bushing got so tight it would not shift.
I was thinking more of a dry lube on the pins and on the end of the springs to assist with any bind
Pstn head
No lube zero nada nothing
Ok I will keep that for the BR. LOL
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
15,660 miles on my Attak......clutch was re-machined for sheave grooving but never lubed.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Glide washers work well in spring perches. TP sells them.end of the springs to assist with any bind
