langow
Was replacing the rollers in my secondary and was wondering if the recessed area where the little washer sits against the rollers is normal, or has this worn into the casting from use? When I started assembling the new washer and roller, the washer is thinner than the recess and it looks like the roller will rub on the casting. Thoughts?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
That casting should not have that pocket. The washer has worn into the casting.
langow
Crap! That's what I was afraid of. Can I just double or triple up on the washers to correct for this? Or am I screwed?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Replace that part of the clutch. Out of balance and extra washers will make it worse.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I'd clean it up and epoxy/glue the old washer right back into the worn pocket so it can't spin. Won't hurt a thing, let the new roller ride right against the epoxied in washer.
I'm finding the roller wears into the clutch even without washer, especially the stock Yamaha roller.
Is there any reason why another washer can't be added if there's room...? I see no reason why not.
The stock Yamaha roller needs to go. Even on a new machine it is only a few thousand miles and then they also start to wear into the surface of the helix.
langow
That's exactly what I was hoping would work! Thanks for the confirmation that it should be fine.I'd clean it up and epoxy/glue the old washer right back into the worn pocket so it can't spin. Won't hurt a thing, let the new roller ride right against the epoxied in washer.
