2019 Sidewinder Vibration
Hi Guys...good news update. Thanks for all the advice. Learning as follows, I swapped both clutches from my sidewinder to my my SRX and vibration went away, isolated alittle more per clutch and found the secondary to be at fault. Started to disassemble secondary and found two of the three nuts holding the helix down backed off just a tread causing the helix to flex away from clutch. See pic it actually ovoled my helix holes. Swapped out helix, new nuts, torqued to spec & no more vibration. Some thing quick to check for future vibration issues.
I use a little drop of blue locker on those every time i remove them
Thats a new one I've never seen before. Glad you found it.
