loudelectronics
- Dec 1, 2007
- Souris, Manitoba
- presdwr.spaces.live.com
Anyone that owns an early model 190 kit should know this. The early kits did not request that the barometric sensor be connected to the intake. With out this your machine could be running extremely lean. Also altitude compensation does not work effectively and again causes your machine to run lean.
Its a ten minute job, pull the baro sensor on top of throttle body (its the one with out any hoses connected and on throttle side of the other pressure sensor) connect some tubing to nipple and run to the join on the intake turbo hose. Pull the hose apart and tap into the aluminum to install a nipple. Reconnect and problem solved.
I was seeing AFR's near 17:1 before connecting the baro sensor. After my AFR's are 11-12.5:1.
Tanker Yanker
- May 4, 2014
- Davidson SK
- 2015 Yamaha Viper XTX LE
2009 Yamaha Nytro RTX
CouldAnyone that owns an early model 190 kit should know this. The early kits did not request that the barometric sensor be connected to the intake. With out this your machine could be running extremely lean. Also altitude compensation does not work effectively and again causes your machine to run lean.
What do you mean by early kits? Could you post some pics?
Tanker Yanker
- May 4, 2014
- Davidson SK
What do you mean by early kits and could you post pics?
loudelectronics
- Dec 1, 2007
- Souris, Manitoba
Don't have any pictures right now. On the top part of plenum there should be a nipple to connect to baro sensor. If not then you have an early kit.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Mine has the nipple on the intake but the instructions didn't say anything about connecting the 2.. guess I'll have to look into that! Good info.
Tanker Yanker
- May 4, 2014
- Davidson SK
Thanks for the info i will look into it.
