Saskapex
Was wondering if anybody knows if the timing gets changed when you go from a mcx 260 to 290 on an apex? Or do they leave the timing the same and just turn the boost up? Thanks
helmic
- Nov 10, 2008
- Bathurst N.B. CANADA
- 2014 Apex SE STUDED,PC5,D&D Performance Exhaust,MAX-REV intakes,D&D BullsEyes,Ulmer clutch kit.Yurbo coming soon!!!
timming
It the same setting,no change just the fuel mapping up grade.
Saskapex
Alright. I figured it wouldn't change. Just wanted to make sure! Thanks!
helmic
- Nov 10, 2008
turbo
Your welcome...
Your welcome...
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
X2 on what helmic says.
Only time it changes is when you add or retract thickness to the head shim or head gasket. That will change the geometry of cams relative to crank.
