Fleecer
- Jun 13, 2014
- 2019 SRX
I want to put the stick shields on the SQ, did you do it and if so any pics?
This should help.
https://www.google.com/url?sa=t&sou...FjAEegQIARAB&usg=AOvVaw2i1Qnbym_IVoVLR_SivYEY
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
i have both super quiet from Turbo Dynamics and Factory modded... heres what they did.flo
I think it's good to keep in mind its not only the diameter of tubing in an exhaust system but really what performance needs is FLOW. So, increasing the stock muffler outlet to 3" might, on paper, sound like a great change to make but my question is, what about all the internal passages and tubing? Can it all flow what a 3" outlet can flow (that means starting from header through head pipe to turbo housing into muffler head pipe, into muffler internal baffles, and out the outlet)? If there is any place in the whole exhaust stream where it can't flow what a 3" outlet can flow, there is a restriction (and the 3" outlet pipe doesn't matter). An exhaust system will only flow as much as it's smallest orifice in the entire system.
I think this might be what NYTurbo is alluding to and maybe why the vendors who modify stock mufflers charge what they do. It's allot of work to go inside the stock muffler and change all those orifices to 3" (or 2.5" or whatever).
Also, even if a 3" outlet pipe helped (that assumes all the rest of the internal parts in muffler can flow what that 3" outlet pipe can flow), I've read here in TY that in some places, law enforcement is simply measuring the size of the muffler outlet and comparing that to the OEM stock specs and if it's not the same, you get a ticket even if your exhaust system sounds stock (has same dB readings as stock).
That's what I have done on mine for last few years now.im going to put the two button head bolts in the open holes with nuts on back side to make look stock.
Turboflash
- Mar 18, 2019
- Southern MN
X2. I just used the stock bolts with nuts on backside.That's what I have done on mine for last few years now.
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Did same thing with mine.im going to put the two button head bolts in the open holes with nuts on back side to make look stock.
SideHogger
- Apr 16, 2016
- upstate ny
Did you have to request this because mine is just straight 3”.i have both super quiet from Turbo Dynamics and Factory modded... heres what they did.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
yes i asked them to do soo the cops when looking under all they see is 2"... looks stock at quick glance.Did you have to request this because mine is just straight 3”.
- 18K
