studdog
Anyone have factory initial setup instructions for the new suspension? Looks to me the rear spring adjustment is no longer threaded so you only have the shock cam adjustment and of course the c-clip. Any info apprciated. Studdog
flyinwrenchz
the rear spring on my 06 vec. wasn't threaded. Rear suspension on these sleds is probably the easiest to set up I think. First set your spring setting for your rider weight. Second set your transfer rod for your riding style or whatever you prefer ski pressure, wheelies, light steering feel. and then use the dial for varying conditions harder for those rough days and softer for the ultra groomed days. That is how I had my 06 set up and did my 2010 the same way. hope this helps. I thought my 06 railed awesome so I set the 2010 the same way figured it should be a good starting point.
studdog
Thanks Flyinwrench. Do they recommend a measurement of spring length for 2010 Monoshock II anylonger?
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
sag should be set at 40mm-45mm on the ohlins EC
studdog
The sled is a 2010 Vector LTX GT. Non electric Track shock. No threaded adjustment just spanner wrench ans c-clip.
