YaMon
I have Powermadd Guards already mounted between the grip and the brake clamp. How do you get both the guards and left hand throttle mounted in the same place. Does someone make a bracket that will work with both?
AaronBND
This is a great question. I fought with mine last month and finally just pulled the brand new handguards off. Pain in the A**! If you come up with anything let me know!
Aaron
Aaron
Colorado Yamaha
- Sep 4, 2005
- Colorado Springs
- 2010 Nytro MTX - MCX
YaMon
I can't beleive nobody has done this with stock bars. What is wrong with the stock bars. I really don't want to have to change the bars if I don't have to. Plus I need the guards for riding through the trees, will never do that again. Someone please come up with some way to make this work.
Colorado Yamaha
- Sep 4, 2005
- Colorado Springs
YaMon: I have put a Gold Finger and Power Madd's on a stock Apex Mtn., but I used the Sport Tech adapters that TJ Sports sells, works really well. It's tight but there is room for the GF and with the adapters from Troy, those mount inside of the mtn bar post. I did these in the trailer, pretty easy. D
