MNSnowScooter
In search of some advice on my 2014 Viper with MPI Turbo and a Ulmer tuned PCV.
Here's the issue: sled runs well at first start up, down the trail no problems. When I give it medium to heavy throttle and let off the sled will surge and die. I've sprayed carb clean thinking it was a vacuum leak but no surge when I'm spraying. I will continue to search for vacuum leaks but looking for some other ideas.
-if I come to a stop sign with my thumb putting a small amount of pressure on the throttle it won't die. If I let go it would die.
MNSnowScooter
Yes I have an afr gauge.
MNSnowScooter
Can't get the video posted. Afr at idle is typically 11 ish range
You have to post vids on YouTube or Facebook and link them. Whats the AFR say before it dies. Is it 9? Could be loading up. If it won’t run at idle without throttle then it could be the map sensor.Can't get the video posted. Afr at idle is typically 11 ish range
MNSnowScooter
Is there a way to test TPS voltage? I can't find my service manual atmYou have to post vids on YouTube or Facebook and link them. Whats the AFR say before it dies. Is it 9? Could be loading up. If it won’t run at idle without throttle then it could be the map sensor.
I’d have to look in the manual for the volt number and procedure. Maybe someone else will chime in. @SrxspecIs there a way to test TPS voltage? I can't find my service manual atm
RobX-1
- Coldwater, OH
Thank you for helping out!!
MNSnowScooter
Still struggling with this issue.....
-AFR before shut down is 10.5
-TORS/throttle cable has been adjusted more loosely then the recommended credit card
-throttle position closed and open is within recommended limits.
-checked all clamps to make sure I have no unmetered air coming in. I used carb cleaner while it was running to see if the rooms changed....no luck.
Not sure where to go from here besides tearing everything apart and making sure everything is seated and no air leaks.
