Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
I'm just worried where the exhaust goes into the muffler , right side up by the drivers knee area I guesseNo the exhaust itself does not get that hot, if your talking about the muffler. And the weight in the clutches as you run more hp is the problem. I think at 12#'s I am somewhere around 98 grams and as the new motor broke in I started seeing 13#'s and banging off the rev limiter. The helix makes a big diff also the power comes on so fast in these things that the shift out on the primary gets ahead of the secondary and at launch I was getting a lot of rev limiter. It seems that a straight ramp works better and is more linear for the bigger hp machines.
Will the ulmer clutch kit I have help the clutch problems your talking about?
I am not sure what clutching problem your having but Allen's stuff is dead on. You can go with a cheaper set up but will spend a ton of time tuning it. Hauck originally built my sled and put his kit in it. I was back to him maybe 4 times cause it was way off and that was when I was only at 6 #'s of boost. I took the sled to Ulmer after the motor work was done - threw away all of the Hauck crap put his kit in it and other than the hp increase after the motor broke in it was spot on. I only bang the limiter when the track breaks loose.
I was not having problems it was making so much hp that I had to add weight. Most kits can only go so far but with Allen's I believe I can get closer to 110 grams
I am going to find out cause when I get it back from Allen it will be blowing 20#'s into it and be closer to 330 hp
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Ok I get you now. It sounds like you got boost fever!! Im just starting this year with the 190.
I'm waiting for my ulmer clutch kit to come in.
It's not a fever it is full "blown" disease. I will now have 2 turbo vipers 1 nasty trail and 1 just plain nasty
nick herting
- Oct 12, 2014
- palatine bridge
- Yamaha apex nitro viper srx
hey yamadog do go or have you ever been to the lakewoods weenie roast ice drags in cable wi. ?It's not a fever it is full "blown" disease. I will now have 2 turbo vipers 1 nasty trail and 1 just plain nasty
Nick I tried to go last year and had a schedule conflict I am planning on going there this year and every radar and ice drag I can make
nick herting
- Oct 12, 2014
- palatine bridge
nice I have been goin to this event for the past 8 years, and im from NY .lot of funNick I tried to go last year and had a schedule conflict I am planning on going there this year and every radar and ice drag I can make
Hope to see Ya there we will have some fun and yes that's a cruise from NY I am from Hershey PA moved out here 15 yrs ago its a lot closer- I am less than 2 hours from there. I actually have a cabin about 40 miles south of there now and just put heat in it for winter stays. they don't get the good snow there though so I ride mainly Hurley and up into the UP.nice I have been goin to this event for the past 8 years, and im from NY .lot of fun
