wavemaster
- Mar 6, 2009
- New Hampshire
- SR Viper XTX, Nytro XTX, Phazer FX
What are the stock weights on the 2014 XTX SE?
What is the stock helix?
- Apr 14, 2003
- Hessel, Michigan
Stock helix is a 43 straight
Weights are 8GL and they don't put enough pressure on the belt. Need aftermarket adjustable weights or heavy tip weights from yamaha. 8FP weights are working for me and others who we have told.
Terry
Terry
wavemaster
- Mar 6, 2009
- New Hampshire
I had to do some guessing, do the parts below look right?
Weight Comp UR 8FP-17605-00-00
Spring, Compression UR (GR-WH-GR) 90501-603L3-00
Rivet (St13.3) UR 90266-06002-00
http://www.yamahapartshouse.com/oemparts/a/yam/5330763ef870024560f040fe/alternate-drive-setting-1
Yamaha YXR Clutch Shim Kit 1-5mm - YXRSHMKT
http://www.benderracing.com/Yamaha_YXR_Clutch_Shim_Kit_5mm_Total_p/yxrshmkt.htm
45/39 Advant-Edge I could not find this helix
I did find the 46/40 Dalton helix here
http://www.ulmerracing.com/helix.htm
V-Belt 8DN-17641-01-00
http://www.yamahapartshouse.com/oemparts/a/yam/5003c734f8700212fc842ff6/primary-sheave
- Apr 14, 2003
- Hessel, Michigan
Yes, run the Dalton helix. ... looks correct!
Wave master can I copy your post? Very helpful with part numbers.
wavemaster
- Mar 6, 2009
- New Hampshire
Absolutely - just make sure it is right first lol.
yamaha06
Is that the right part # for the 3.5 gram rivet?
- Apr 14, 2003
- Hessel, Michigan
Cannondale....can you check to see if this part # is correct for the rivot? I believe Yamaha goes by the length which would be steel 13.3
Must have missed this question from yamaha06....sorry bud
- Apr 14, 2003
- Hessel, Michigan
Bought some rails from a Cat guy in Colorado, 153" rails from a 2013 Cat. Painted the rails blue and received a used 2.25" track from Stingray (thanks bud!) to make a mountain sled using my 141" XTX chassis.
The best part is the suspension components bolt right into the rails and the 141" XTX geometry is exactly the same as the 153" Cat! Holes are in the tunnel already and I used the lower most holes
Front floats - 65 psi (no load)
Rear suspension - front shock 14 threads showing
Limiter straps moved 1 more hole from center holes (shock was just at it's max. length)
rear float 120 psi
- Apr 14, 2003
- Hessel, Michigan
Here are my latest settings.....
Front shocks 65 psi
C&A Pro skis (changed from stock)
Center shock 14 threads showing (bumped up a little)
Rear Float 135 psi
153" Cat rails and 2.25" Power claw track
PC5 with autotune (added)
Airbox modded
Evolution Powersports Header and Muffler
Machined clutches
Sled corners awesome even with the large lug long track.
Jumps? it's ready
Front shocks 65 psi
Rear Float 135 psi
Airbox modded
Machined clutches
Jumps? it's ready
