freelance
- Apr 15, 2013
- Manitoba, Canada
- 2014 Yamaha SR Viper XTX SE
65 psi up front
125 rear skid shock
Front skid shock halfway
Limiter straps middle hole
5'10"
210lbs with gear on
Never bottomed out once but it could buck me off the seat if I don't hold on tight....LOL !!
125 rear skid shock
5'10"
210lbs with gear on
- Apr 14, 2003
- Hessel, Michigan
- Apr 14, 2003
- Hessel, Michigan
MBRP can is on and very happy with the results
Last ride was 4/20/14
So happy with my settings, haven't changed anything
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Glad you like the viper with and either out the can. Much difference in 'loud'?
- Apr 14, 2003
- Hessel, Michigan
yamadoo said:Glad you like the viper with and either out the can. Much difference in 'loud'?
Mark, the can is perfect as far as everything goes....fit, ease of adjustments, heat disipation, sound (little over stock, not obnoxious....has a tinny sound to it, not barky), loss of weight, price compared to other cans and of course any extra power makes it all that much better.
Made me love the Viper even more now!
dlinebacker36w
yamaha viper
What is your top speed with the xtx and list your mods. Nos pro what is your final top speed after testing and adding exhaust and other mods. And how many feet are you seeing these numbers approximately. Thanks
- Apr 14, 2003
- Hessel, Michigan
Sorry for the delay, raced my SRX this weekend and worked around the house yesterday. Didn't check TY at all this weekend.
Clutching at the end is:
Primary clutch
8FP weights, 3 gram rivots in the tip
Green White Green spring with 1MM spring spacer
Stock rollers
Secondary clutch
The 45/39 Advantage helix worked well for me and I tried Shagman's 46/40 Dalton helix which worked good also (washers under the helix to prevent coil bind)
Pink (stock) spring set at 6-1
This last time I had it out was with the can installed and the conditions weren't good at all. 50+ degree temps and zero hard pack to get a good run. I saw a best of 97 in conditions you would only see about 82mph on a stock Viper. I do know I will need to put a little more tip weight in as the can did raise my rpm's to the point where I am hitting the rev limiter. Once you keep hitting the rev limiter, it knocks off speed fast.
My top speed on the gauge has been 107 and on GPS is a documented 105.1
I know it's faster now and just need perfect conditions to prove it. The sled is stock other than the can and clutching parts.
Primary clutch
Stock rollers
Secondary clutch
MorganKoda
- Dec 26, 2013
- Lakeville, MN
- 2014 SR Viper XTX
NOS are you still with the stock belt or did you switch to the 8DN as well?
- Apr 14, 2003
- Hessel, Michigan
I switched to the 8DN also.
I didn't like the 8JP, left too much black on the clutches and didn't perform with the Viper "Stock" clutching. I might go back to it and try it if I get the clutching to grab the belt more to prevent slippage.
- Apr 14, 2003
- Hessel, Michigan
I moved this thread up as there have been a lot of PM's and posts about my setup, which is awesome!
Lots of good info here for the new guys just getting their new Vipers
yamahatime
- Nov 4, 2012
- 2014 Yamaha SR Viper XTX with Skinz can, Skinz airframe running boards, Skinz skid plate, Skinz rear bumper, Skinz Arc A-arms with Fox EVOL shocks, Skinz storage bags.
Good info
- Apr 14, 2003
- Hessel, Michigan
Thanks yamahatime, saw you picked up a viper
yamahatime
- Nov 4, 2012
Hey NOS-PRO, I did get a Viper. I'm pumped and apprehensive at the same time. I worry about the Cat chassis a little, but somewhat confident in Yamaha's influence. Previously working at a Yamaha dealership for 8 years, I did get some input from the Reps I still know. Teetering on a turbo...
- Apr 14, 2003
- Hessel, Michigan
I was worried at first also, but riding it made me a believer.
I put mine through a lot, jumping, deep snow, fast trail and off-trail and the only complaint I had was spring came too fast!
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
I put 3000 miles on mine without doing anything buy tighten some loose bolts and change the stock carbides.
That's 3/4 of the life of a 2 stroke sled right there. With all the info that's been put on this site over the last year you will be having fun.
