chrisinparts
- Feb 10, 2004
- dearborn mi
- 05 rx1, 10 nytro, 10 z1 turbo
05 rx1 cpr turbo installed by simon. need ideas this sled will not pull rpm. hh clutch kit 61.5g 7/16 steel in 2 hole nothing in tip 3/4 allen in heel 9-1 spring setting. will not go over 9500 rpm, i keep pulling weight out of clutch and there is little change. so i dont think its a clutch issue. it seems like a fuel problem. this sled only has 50 lake miles on it. starts and idles fine. pulled plugs 3 were very clean new looking 1 was a little rich. new plugs installed no help, checked for stuck needle valve, looked fine. looked at tees, vent lines all look good. 112 torco split with 89 fuel. boost guage shows 7lb low and 9 high. exhaust temps at wot between 1200 and 1400. today at anchor bay, sled bogs till about 20 feet out then goes to about 9300-9500 rpm and drops down to about 9100 and stays there. any ideas will help. thanks chris
