need dimensions
pat the rat
earlton,northern ontario canada
i need the outside diameter of the anti bottom rubber pcs and its lenght for the phazer, if anyone knows it.seen the kit and its so simple, i will make it myself.we have lots of rubber and teflon where i work so wont cost nothin,just need the measurements
anti bottom rubber,it bolts to the side of the rail,there is three holes in the rail you can bolt it on,it is a kit from yamaha you have to buy for the phazer,dimension of that pcs would be nice
I have a set off of my 05 Vector. I will measure them tonight & post the sizes tomorrow. I know that the rubber is a very hard durometer & that it actually spins freely on the steel bushing. When the spring come into contact with the rubber there is a forward roll to the rubber. I will post the sizes of all the parts.
its ok,i got it off pat's sled today,they sell those for $65,thats nuts,when i saw how easy it was to make,i made a set in about 1/2 hour where i work for out of teflon,the yamaha ones are rubber but its gonna work just fine
looks like a great idea. I'll be doing something with my FX. What were the dimensions? I have access to teflon and solid rubber at work also.
1 1/2 diameter by 1 3/8 long,you need to put a bushing in the centre,i used a pcs of pipe 9/16 outside diam by 3/8 inside diam by 1 7/16 long,i put the pipe in the lathe to drill it out to 3/8.i made another set but 2'' diam instead,will be testing both
I made some today...2 inches diameter x 1.5 lenght
they seam to work! i will tell you more after weekend...15 inches to come meteo guy said!!! :jump: :Rockon: :jump:
