Need ideas & pictures of hood Holes&vents Frt.mount
Turbo Perogy
Hanna Alberta Canada
Looking for Ideas to venting under hood heat on frount mount Turbo,
pictures of locations would be nice as well any ideas or products such
as hood scoops , looking at BPI scoop anybody try it?looks cool a 4
scoop insert would be even cooler. [/b]
heres some
This part replaces the plastic inspection plate, and is designed to work in conjunction with the BPE scoop to promote airflow through the IC core. You can check with Jeff at Simons CPR - I believe he has them in stock.
4 Stroke - Yes, the louvered piece replaces the plastic inspection plate immediately below the oil filter.
What part of Canada are you in?
Been waiting 2 mths for my louvered piece and scoop, sent a money order mid dec. , now he will not even reply to my emails,I even asked for my money back as they seem to have a delivery problem! come on BPE #*$&@ or get off the pot!!
I like my hood & side vents, there is little to no heat kept in the engine compartment. The side panels are tough to see, but they are the same material. D
