CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
I just checked build date and looked at the engine. I have the new engine I think compared to the pictures here. Build date is 05/2015...
As for the starter issue, mine was only hard starting in the -25 cold and never kicked back. Just wouldn't start right away. But a lot of other cats were having problems that morning also. Eventually they all started except my buddies doo which normally starts instantly! So I had the last laugh that morning!
Clyder6R
- Dec 24, 2015
- Atlantic Canada
- 2015 Yamaha Viper MTX 153 McXpress 190 kit
Found this thread when doing some research. The Dealer has 2 MTX 153 SE vipers left. I want one, but i dont want a motor that will blow when i turbo it.
So from what i read the old motor is the better motor without the weak rods? And to tell if you have the old motor is by build date or the valve cover gasket. Do we have a date range for the old motor? The dealer is 2.5 hours away and they could tell me the build date easier then sending me a photo of the gasket.
So the new motor has weaker rods but is everything else better then the old motor?
Also on a 2016 Viper MTX 153 SE what else comes with the sled, i have read about a ogio bag and a performance damper? what is that?
Tell them to send a pic of valvecover. Takes 2 min and is only sure way to know.
Clyder6R
- Dec 24, 2015
- Atlantic Canada
But I am right in the valve cover info? That' what I will do
Yes if rubber black cam half moon plugs are visible it’s the good old motor that many have put Turbo on and rods hold up fine.But I am right in the valve cover info? That' what I will do
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
Just looked up the 2016 Viper MTX 153 SE and from what I could tell it has the 16.5 motor. all the 153 do It don't have the black cam half moon plugs.
Well then decide if you will turbo before you buy. Another good possibility is if you turbo just change the rods and Pistons. Then can put big boost to it.Just looked up the 2016 Viper MTX 153 SE and from what I could tell it has the 16.5 motor. all the 153 do It don't have the black cam half moon plugs.
SwedeViper
- Nov 7, 2016
- Norrbotten
- Sweden
- Viper M-TX 2016 MCX 270
Local guy here in the north of sweden that played a little with his 2016 viper in spare time.... big boost!
