Vmax
- Mar 20, 2018
- Lasalle
- 2023 ZR 6000
I have heard that Yamaha has a new 2021 flash for the 1049, is this true and if so did it help with performance and starting
Vmax
- Mar 20, 2018
- Lasalle
- 2023 ZR 6000
I guess it was false new....
Perrdog
- Mar 27, 2021
- Pa
- 15 sr viper
I'm curious also
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
The latest flash update came out in the fall of 2018. Nothing has been offered since. As far as performance, most stated better throttle response. On the starting side, it seemed to do away with the starter kick backs for most, improved cold weather starts and warm motor starts.
Big Pussy
- Apr 12, 2016
- Woodstock, Ont
- 2015 XF7000 LXR
The last flash turned my XF7000 into a Catillac.
HydrogenCyanide
- Oct 21, 2020
- Fort Erie
- 2006 Yamaha RS Nytro
2006 Yamaha Apex
Is there a way to tell if you have the new flash?
Vmax
- Mar 20, 2018
- Lasalle
- 2023 ZR 6000
Good question...I bought my 2015 ZR7000 back in 2018 and the dealer did a upgrade flash before I picked it up. The only reason I brought this up was because a guy on TY mentioned that a new flash happened in 2021 for the Viper and told me to look into it ??
I have no issues with mine but if they can come up with a better cold start flash I'm all in
Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
Pretty sure you can call a dealer and they can run your VIN and they should be able to tell.
HydrogenCyanide
- Oct 21, 2020
- Fort Erie
2006 Yamaha Apex
Vmax
- Mar 20, 2018
- Lasalle
- 2023 ZR 6000
Yes, plus in extreme cold folks have had start issues
Lee Rivers 1
- Oct 18, 2014
- 2009 Nytro RTX
I just read on Hard Core Sledder that there is a flash for 2021 Vipers. Anybody know the real story? It is supposed to improve the cold weather starting ( I'm in Manitoba, we get lots of -30c ) , and improve the performance to Nytro power and speed. I'm going to take to my dealer too.
HydrogenCyanide
- Oct 21, 2020
- Fort Erie
2006 Yamaha Apex
So without this update is it normal that it turns over for a good 4-5 seconds before it fires? Mine is an zr7000. Not sure if that is relevant or not.
Lee Rivers 1
- Oct 18, 2014
- 2009 Nytro RTX
My 2016 LTX DX turns over 4-5 seconds then starts and usually stalls once. Has always done it. The new flash is supposed to solve that issue and up the performance a bit. Who knows what that means. If it will start better then my starter should last longer.So without this update is it normal that it turns over for a good 4-5 seconds before it fires? Mine is an zr7000. Not sure if that is relevant or not.
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
What new flash? I’ve not heard or seen anything about it, neither has dealer?
super1c
Moderator
- Apr 10, 2010
I’m at my last straw with this sled and it’s cold start issues. Been to dealer numerous times to find nothing. I’m hoping there is something to this.
