philsummers21
philsummers21
philsummers21
philsummers21
And i posted a pic on another thread ill try to find for the nozzles inside the airbox. System is really easy to put in and is almost dumby proof. For the nozzles i got a 3/4 strap of aluminum and bent the sides so it makes C shape. notched 2 slits in the side of the air box 1 on each side for the aluminum strap to slide into. Drilled 3 holes for the nozzels and plumbed it all in to the Smart box and the fuel bottle. Works great. The airbox lid holds the aluminum strap into place and the lines run through a hole in the bottom of the airbox.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
sonds
- Oct 7, 2008
- Golden Valley MN
- ductworksmn.com
- 08 T-Nytro
Do you need or have a fuel controller?
philsummers21
Nope with the new Boss system a fuel controller is not needed.
splaterwin
What's the expected HP gain when engaged? How much to refill bottles?
philsummers21
60hp shot. they have a stage 2 kit available which is 120hp. I buy a 20lb bottle and refill my little bottles off of it. its $3 a pound this way. Next year ill be purchasing a 60lb bottle to refill with and it will be $2.50 a per pound.
