Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Does anyone know the size of the roller bolts?
I might look for washers today
krm
- Apr 22, 2016
- ny
5mmDoes anyone know the size of the roller bolts?
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
thanks
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
just to clarify.. there are two issues...the bolts excess slack for the rollers and the weights surface to the rollers gap...washers or o rings solve the first...I think theres a performance gain by solving the second...some OSP bench tools and a spider shim is in order for me..
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Nylon washers
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Anyone?
krm
- Apr 22, 2016
- ny
yesAnyone?
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
krm
- Apr 22, 2016
- ny
look at how much play is between the weight and roller .there's some of the noise also .lol
thanks
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
I will check that out
You guys know clutch is on a stub shaft not crank right? Do some research this has all been covered before. When all is done it will still make noise at coupler where a Gear Reduction belongs!
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
I agree
but the roller bolts alone might drive me nuts...lol
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Yes, I have lived with the loud clutch, and it performs well-much worse on one then the others. The stub shaft seems to be the source as those who 'locked it down' with special forms of Loctite stated it ALL went away on the Vectors. While those who used nylon or silicone washers saw only slight improvement and short lived if I recall correctly.
Lots of posts about 1-2 year ago.
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
thats true, the rattle is more noticeable on the 3 cylinders.
Just think if there was a gear reduction. Motor could run at 12000 rpm easy like Apex or Phazer and clutches right around 8500rpm. Thats how it should be.
