actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Does the iceberg that forms in the front grill contribute to overheating?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
No, not to water temp, it could however promote hotter intake temps. That is an intercooler up there, not a radiator.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Yes I would say air temps,IAT temps,when warm outside and snow covered grill my IAT,s rise.Does the iceberg that forms in the front grill contribute to overheating?
Joseph Levandoski
- Oct 19, 2016
- Ellington, CT
- 2019 Yamaha Sidewinder X-TX LE 141
Last season, I was packing the intercooler with snow when playing off trail (leading to 70°F - 90°F air intake temperatures). This summer, I purchased an Arctic Cat Pro Front Bumper (P/N 7639-301) in hopes that it would help prevent this from continuing to happen (or at least limit the issue as much as possible). So far, the bumper has kept the intercooler clear, even when running in deep powder (and helping keep that air charge down between 25°F to 32°F). Even when I was liberal with the throttle and sitting at 85+ MPH for those long northern Maine railroad beds, I only saw my air temperature climb as high as 42°F - I'd call that a success.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Wow for those temps it was well worth the money.Last season, I was packing the intercooler with snow when playing off trail (leading to 70°F - 90°F air intake temperatures). This summer, I purchased an Arctic Cat Pro Front Bumper (P/N 7639-301) in hopes that it would help prevent this from continuing to happen (or at least limit the issue as much as possible). So far, the bumper has kept the intercooler clear, even when running in deep powder (and helping keep that air charge down between 25°F to 32°F. Even when I was liberal with the throttle and sitting at 85+ MPH for those long northern Maine railroad beds, I only saw my air temperature climb as high as 42°F - I'd call that a success.
Joseph Levandoski
- Oct 19, 2016
- Ellington, CT
I never noticed a difference in performance with such high intake temps, but it definitely was an area that I wanted to improve (kudos to Yamaha in making an engine that is smooth in it's performance and holds true to it's intended power output).
Is the Arctic Cat 9000 grill installation as easy as taking out the screw, popping out the grill, and reversing the process with the new piece?
number1kyster
Yes.
I have run both grille's. They both end up built up in ice. The Yamaha grille is easier to chip out the ice.
KillerBee
- Jan 1, 2010
- Waukesha WI
- 2018 Sidewinder LTX LE 50th
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
On the contuary I have had IAT,s as high as 100f plus,on warm days,and high speed runs.Last season, I was packing the intercooler with snow when playing off trail (leading to 70°F - 90°F air intake temperatures). This summer, I purchased an Arctic Cat Pro Front Bumper (P/N 7639-301) in hopes that it would help prevent this from continuing to happen (or at least limit the issue as much as possible). So far, the bumper has kept the intercooler clear, even when running in deep powder (and helping keep that air charge down between 25°F to 32°F). Even when I was liberal with the throttle and sitting at 85+ MPH for those long northern Maine railroad beds, I only saw my air temperature climb as high as 42°F - I'd call that a success.
Arctic grill with Frogskinz
I first stretched / folded it to shape with gorilla tape and then lifted each side up (carefully) and applied VHB tape to the edge of grill. Takes some snipping of corners with scissors. I made two of these in about 2 hours. I have buried the nose and no packing. Also easier to grab front bumper!
- Arctic grill ($12) and sheet of frogskinz.
- Sand down sharp corners
- Attached with VHB tape.
