zichm
- Jul 14, 2009
Can anyone give feedback on the float plate for the Nytro
GT03235
I got a skinz and it transformed my sled into a more floating snowmobile off trail not a plow
wh2oscott
I also have a skinz. i bought it to add flotation and it does a good job. I also really like the looks.. I would not recommend it to anyone who cant melt down their sleds.. it has some tremendous ice buildup after a day in the fluff.. the ice forms around the front suspension and Swaybar. I removed my swaybar and it got a little better, but still a lot of ice.... I call my sled the "Ice Machine"
stook
dont waste your money huge ice build up,so much that it will pull the screws through the plastic and it will be just about dragging in the snow.There is a template to cut holes in it to let the melted snow drain out but what is point of having a plate with holes in it for something to catch on and rip it right off.
GT03235
stook said:dont waste your money huge ice build up,so much that it will pull the screws through the plastic and it will be just about dragging in the snow.There is a template to cut holes in it to let the melted snow drain out but what is point of having a plate with holes in it for something to catch on and rip it right off.
I am on my 3rd season with my skinz plate and i do agree about ice build up, but the advantages i have far outweigh the the negatives in my opinion.
I always spray the float plate on the top with silicone which helps greatly.
enticeraised
Yamaha OEM is junk. Sled weighs 40 lbs heavier by the end of the day.
Good quality-poor function
X3 skinz in junk, collects retarded amount of snow which turns to ice. I trimmed the sides off to match the bumper tubing after only 2 rides it was sooo bad. Caused overheating even in cold weather.
enticeraised
Take a close look at my picture
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
I've rode with the oem float-plate for 2 years now, on 2 different Nytro's and think the good out weight the bad, yes it will hold some ice, you just have to keep an eye on it and deal with it, and I trimmed mine just a little on the sides to relieve the ice build-up under the a-arms.
Muffin
- Oct 5, 2006
- Marathon, WI
- 2014 SR Viper RTX SE
I've had the Yamaha and the Skins. IMO the skins is much stronger, has a better mounting system and holds less snow and ice. I am using them with the mountain floatation bumper. I would'nt run without a skid plate. Get the skins and you will be happy.
Muffin
Muffin
FJR1300
I bought one Skinz and one Yamaha. I ended up cutting the Yamaha because it collected snow. The key to both plates is to use automotive weatherstrip on the area directly under the stock plate. This 3/4 x 3/4 strip in the shape of a "U" will keep the ice from forming between the two plates
Mountaintech
northerndoc
Yup. Just get the Roest. Gives extra flotation, eliminates the cheesy OEM plastic/aluminum skid plate, and will take a pretty solid hit from a stump without so much as damaging the powdercoat! (did the beta testing on that one myself ).
Mountaintech
Lots in stock.
09nytro
will it help you floatRoest said:This blows everything else away.
