snopro24
I had my kids playing around in my garage and left my key on and it drained the original 09 battery. I tried to charge it on 2ah and it wasn't able to pull a charge. I replaced the battery and still nothing. I checked the fuses by the brake rotor and grounded the starter solenoid with a screwdriver and it turned over. Thoughts?? Relay issue?? What else can I check?? Thanks in advance...
603NytroXTX
- Aug 19, 2012
- Salt Lake City
- 2009 Yamaha Nytro XTX
2010 Yamaha Apex LTX-GT
- Salt Lake City
Sounds like it is your Starter Relay Solenoid. Had the same exact issue with my 09. One day it started to get picky on me with starting and then the next it wouldnt turn over. Its caused by moisture basically. Like a $25 part and you are good to go.
snopro24
Ok thanks...anyone have a part number for that?
sneakattak88
8GL-81940-00-00 should it.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
kids playing? check the kill switch.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Thanks Grizz, You beat me to it! Seen that before. LOL
snopro24
Well I checked all of the wiring going to the kill switch and all is good. So going to try the starter relay solenoid.
Supa Dexta
He meant simply the kill switch pushed down, not the wiring. Do you have a tether? check it too.. Simple stuff first.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
If it won't crank it's probably corrosion in the connectors or a bad starter relay. I had a problem with corrosion in the ignition wire connector but it didn't appear to be bad. The connector had just enough oxidation on the connections to cause a problem. After a good cleaning and adding anti corrosion grease I haven't had a problem since. Check out the fax section for diagnosing start problems: http://www.ty4stroke.com/viewtopic.php?p=931403#931403
