Hey guys.
I have a 2009 Yamaha nytro and the fuel pump won’t turn on. I have 8.4 volts to the connector instead of 12 and still nothing. The green fuse is good, the 10 amp red fuse is good, and the relay clicks when the key turns. Tried two different good relays, swapped fuses, and tried two different pumps and neither work. Any help would be appreciated
