m.p.joyce
- Jan 1, 2018
- buffalo
- nytro
hi yall new to Yamaha sleds. I acquired a 2009 nitro. my problem is the hand warmers get way too hot, to the point of the grips are almost melting. the controller displays correctly on the dash but doesn't control the temperature. where should I start looking
devilnabludress
- Aug 30, 2013
- Eastern Ontario
- 2011 Nytro XTX
Maybe it has Yamaheaters on it. They go to max heat which is crazy hot on the hands when the Yamaha hand warmers are in the off position.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Is there a small light build mounted somewhere on the dash. If yes - then you have yamaheaters.
I don't think the nytro's grips ever created that kind of heat without yamaheaters.
Lol
Ms
Lol
Ms
m.p.joyce
- Jan 1, 2018
- buffalo
- nytro
thanks for the replies, there is a little led light on the dashboard just below the key. just had the sled out for a sixty mile romp. had to stop every few miles to cool bars enough to keep riding. looks like I start searching for yamaheater box. I ride with handlebar bags on my sleds anyway, so which connectors do I unplug to stop bar power?
Dr. FeeLGooD
If you press the grip heater control once to the next level the light should turn green and that is the lowest temp setting. Some yamaheaters are installed with an on off switch.
http://yamaheater.com/Instructions-P-and-P.php
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
If you have yamaheaters the lowest setting on the hand warmers turns them ON to the highest heat amount. The little light turns red.
Toggle the heat bars up on the scale on the dash and the light will go green.
Yamaheaters enhance all heating levels. When the light is red the bars get insanely hot
If you knew all this, sorry for the long message.
Ms
Ms
m.p.joyce
- Jan 1, 2018
- buffalo
- nytro
thanks for the help, this is my first yam sled, obviously not new anymore but runs good, power is good too, can maybe see a spring order for new one this year,i'll see what the light does, wasn't aware how it operated, I figured off was off lol
siccfish
- Dec 14, 2017
- Keswick
- Yamaha nytro
Lol
Ms
My 09 gets real hot and it has the stock warmers
