ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Any results on belt life with big power so far? This may help us decide it the winder clutches are the issue, or if its just a chassie/offest thing..I have now mounted the Viper secundary and Apex primary clutches in my Sidewinder. I dont trust the Sidewinder clutches,so many primary that have exploded and that with stock weights and aftermarked weights. I have run for years 380-390 hp on my Nytro with Thunder produkts weights and with no isues.
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
So you think possibly Daves new balancer/stub shaft would help then?Imo the harmonics and the offset played a major role in the 17/18 sleds. Time will tell.
Id drop 500 on it, if it made belts last...lol
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
If we are just talking the Stubshaft and Primary clutch we know for sure the Stock Stubshaft in a Sidewinder has to be lighter than any before since the Relucter gear was removed. I know that doesnt seem like much but I am telling you guys even a 1/2 ounce in a assembly spinning 9000 rpm matters. That said has anyone ever weighed the old and new clutches?
Whats the stock relucter gear?
The new clutch I would imagine weights more, I can weigh both at some point, but the castings and the spider are much thicker on the sidewinder clutches.
On Nytros and Vipers the pickup for timing reads off the Stubshaft. Sidewinder it reads off the Flywheel so nothing on Stubshaft. Reluctor looks basically like a gear.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
I was curiousIf we are just talking the Stubshaft and Primary clutch we know for sure the Stock Stubshaft in a Sidewinder has to be lighter than any before since the Relucter gear was removed. I know that doesnt seem like much but I am telling you guys even a 1/2 ounce in a assembly spinning 9000 rpm matters. That said has anyone ever weighed the old and new clutches?
3925gr old and 4080gr SW
Awesome! Thanks for taking time to do that and share. Now we know wieght at least on clutch side of Stubshaft does not stop rattle.I was curious. Weighted pin and washer no weight no rooler
View attachment 141516 View attachment 141517
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
I’ve been running a viper primary since last December. It rattles just as bad as sidewinder clutch. Belt life is the same as a sidewinder clutch. But it doesn’t go boom. 1500 miles and no cracks. With our clutch weights I went 5 grams heavier with base weight and setup with same screws as sidewinder clutch.Awesome! Thanks for taking time to do that and share. Now we know wieght at least on clutch side of Stubshaft does not stop rattle.
TT
Does that mean that the nytro primary will fit the Sidewinder?
What secondary are you runing? And what is your offset between primary and sendary clutch?
shagman
Vendor
- Feb 18, 2014
Yes it fits. Stock secondary. Offset is the same. Didn’t have to adjust. I’m set at 61mm offset.Does that mean that the nytro primary will fit the Sidewinder?
TT
Thanks - just the info I was looking for! What torque specs did you use when you installed the Viper clutch - viper og sidewinder specs?Yes it fits. Stock secondary. Offset is the same. Didn’t have to adjust. I’m set at 61mm offset.
Nice info.I’ve been running a viper primary since last December. It rattles just as bad as sidewinder clutch. Belt life is the same as a sidewinder clutch. But it doesn’t go boom. 1500 miles and no cracks. With our clutch weights I went 5 grams heavier with base weight and setup with same screws as sidewinder clutch.
shagman
Vendor
- Feb 18, 2014
Sidewinder spec.Thanks - just the info I was looking for! What torque specs did you use when you installed the Viper clutch - viper og sidewinder specs?
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Wow 5gr is a lot I never thought a result like that! It means that old c'utch work much more freely if I understand well? Now i wanna try it this winter.I’ve been running a viper primary since last December. It rattles just as bad as sidewinder clutch. Belt life is the same as a sidewinder clutch. But it doesn’t go boom. 1500 miles and no cracks. With our clutch weights I went 5 grams heavier with base weight and setup with same screws as sidewinder clutch.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
The reason the Winder clutch takes less weight for same RPM, is the pivot point center being moved further out from the old Yamaha clutch. With the weights further out like that, they generate more shift force using less actual weight.
I've never seen or heard of a Winder clutch actually exploding or going boom on the Winder. I have seen however a HH or HH style of weight breaking at the threads on the weight and blowing pieces of the clutch away after it slams past the roller from being too short or actually breaking, no fault of the clutch in an instance like that.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
Just asking, why does the team primary clutch on AC not break belts? Same motor ,same stub shaft, how could it be all these thing said above?
- 21K
