Ohlins Electronic Shock install on and Attak ER
henseljg2
Ballston Spa, NY
Does anyone know if the stock 06 Attak ER wiring harness have the plug that an Ohlins would go to? I looked around a bit but couldn't find it. Maybe I am blind. I am trying to put an ohlins on my 06 Attak.
not sure if it will have it or not if it has it it will be on the right side above the little rad and chain case. also will need the right speedo for it to work.
I believe all the apes are setup to work with the ohlins, plug should be right by reverse lever runs into tail light harness.
