alex369
- Jan 27, 2017
- ontario
- sidwinder
I just did my first oil change and the operators manual states capacity is 2.8 L or 3 U.S. quarts, I have 2.8 L in now and the oil level is way below the min line on the oil tube. How much has anyone that has done an oil change put in to fill the oil tank ? Also to change the oil with out removing the muffler is next to impossible .
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Did you remove the oil plug from under the belly pan plate and drain that? I try and just use a evacuator in the oil tank to suck that out. Not sure why the muffler has to come out?
TurboWinder
- Jan 15, 2017
- Plainfield IL
- 2017 Yamaha Sidewinder
It takes a bit over 3 1/2 quarts to the max mark. If you remove the foot sleeve it's very easy to get the drain plug out.
alex369
- Jan 27, 2017
- ontario
- sidwinder
yes I did remove the oil plug under the belly pan and changed the oil filter , is that why it is taking more oil ? Muffler removed to get at the drain plug maybe my hands are too big.
alex369
- Jan 27, 2017
- ontario
- sidwinder
The 3 quarts in the manual must be if you do not replace the filter, Yes I did remove the foot sleeve, I managed to do it without removing the muffler but will not do again without removing the muffler or I will get a pump to change the oil.
roweboat70
- Jan 25, 2011
- 2017 Yamaha Sidewinder STX-DX
I had to put in 3.1L after the first oil change with filter change. That is also what the spec sheet says. 2.8L is just to get you close, before you start it to check oil level.
Be sure to bring the sled to operating temp, shut off and wait 5 mins and then check... should be right in the middle if you add 3.1L.
Pstn head
If you remove the torx screw holding the bottom plastics on by your left foot well and peel it away, you can easily fit a stubby ratchet or a short ratchet wrench to aid in the removal of the oil tank drain plug.
BTbt
- Apr 11, 2005
- Kettleby, Ontario
- 2017 Sidewinder LTX LE
I removed muffler, easy to get at drain plug and need to adjust chain tension at first service
YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
There is so much confusion out there, as to when is the best time to change oil... is best to do it before you store the machine or is it best to do it before the season starts? My sled is stored in the garage.. don't know if tha th makes a difference.. what everyone's thoughts?
SaskAttack
- Jan 4, 2006
- Corning,SK.
- 17 Sidewinder XTX-SE
- Corning, SK. Canada
Do you really want dirty oil sitting/settling in your sled for 5-7 months between use? Or stored away with clean oil . Very easy decision in my books.
YukonMP
- Dec 25, 2014
- Yukon Territory
There is no confusion, just differing opinions. If you ask for everyone's thoughts you aren't going to clear anything up.
What makes sense to you? The only thing we will all agree on is that you need to change it.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Far more % do it in the fall. I have always done mine in the fall.
Dan
Dan
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
Always spring for me. Dirty oil acidic. Removing the muffler and applying new anti seize is a good thing.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Dan
X2
mine all get done during the summer at some point when i have them in the garage doing my pre season on them. usually done most of them before end of september and get to working on the vintage/project sleds.
