Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Do you really have to split the chain case to change the oil?....WTF
Can't even get a suction tube down the fill hole
RAMSOMAIR
welcome to Arctic Cat ingenuity!
Couldnt manage to put a drain bolt in the bottom, too much weight lol.
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
That is stupid!!!!
Rich Kay
- Mar 29, 2006
- SE MI. Howell
- Yamaha apex rtx
Totally unacceptable !!! Its hard to give credit to a lead project engineer of the sled when something like this is so little but so important....really . I see it as part of the "CAT" DNA in the sled...Do you really have to split the chain case to change the oil?....WTF
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
While it isn't as easy, it does allow you to inspect the case and flush out any debris that's accumulated
geez150
Coming off ski Doo and it was the same way. I believe that it is their way to promote you to clean and inspect the whole chain case assembly.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Cat management knew their workers don't tighten bolts so they worked around it
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
How are you guys doing it? Suction tube?While it isn't as easy, it does allow you to inspect the case and flush out any debris that's accumulated
mpbrix92
- Nov 30, 2015
- Sheboygan , Wisconsin
- 2009 Yamaha Nytro RTX, pretty much bone stock
Lol IMO this is probably so people take the sled in to the dealer to get the work done, even if it's under warranty you'll usually walk out with something. If the dealer is making money so is the company
SRX Boy
Just a heads up, if you are simply slitting the two halves, don't pull the bolts all the way out - you can end up with oil in the bottom bolt holes and then split the casing when you reinsert the bolts and tighten them down
Sent from my iPad using Tapatalk
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
i use a small pump . it works good and you dont have to split the case. eventually you should though to inspect the case. may 2-3 seasons
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Pulling the cover away from the case, you can do it without unhooking any oil tank lines. Not as bad as it sounds just takes a little extra time.
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Used a tube and a suction pump
That will work for now
BTbt
- Apr 11, 2005
- Kettleby, Ontario
- 2017 Sidewinder LTX LE
X2 on suction tube.I use a piece of 1/4" plastic air brake tubing and vacuum pump,a little slow but no mess.At end of season I will pull cover and inspect.
- Apr 14, 2003
- Hessel, Michigan
Took the words right out of my mouth
It's actually pretty easy guys...just saying.
