Y2GREY
- Jun 6, 2004
- CNY
- 79SRX440, 03RX1 stretched and aired out, 06ATTACK, 09APEXLTX stretched and boosted, 18XTX SIDEWINDER
2018 X-TX with 5200 on the clock. Clipping down the canal yesterday at about 45-50 (yeah slow I know!). Sled was running at about 168 steady temp. Stopped for a crossing and when I started back up to speed I got the red light. No code, no limp mode or shut down. Light stayed on for what seemed like forever but was about 3 minutes then went out and did not come back on the 20 or so miles back. Oil is fresh and level is spot on.
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Weird it didn't throw one of the oil codes
Turboflash
- Mar 18, 2019
- Southern MN
What filter? How long had you been riding when it came on?
What oil?
Have seen one 998 that had bad oil sending unit.
What oil?
Y2GREY
- Jun 6, 2004
- CNY
I was out about 20 minutes. Sled has been running fine completely stock with oe filter and recommended oil. Other thing of note, when I started the sled tonight the screen was lighted but blank and all 4 indicator lights including high beams remained illuminated. After 30-40 seconds the read out started and all indicators but the temp i turned off until it warmed up then that went off as it should.
