I've had the same issues, no factory hose going through the belly pan would probably be an environmental issue, just do it yourself if you're sure there isn't an oil separator issue.Ok cleaned out oil separator with water and dawn dish soap,lightly blew some air through it and sprayed it good with WD/40. There was some water in the separtor when I took it off. I guess my next question is what is gonna stop this from happening again. The air box and the whole under side was just coated with oil unbelievable mess why would they not have a hose coming out of the bottom of the air box to the outside of the belly pan.
