jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Without the ROV bypass done it will blow out even faster.. Maybe onto your right foot while riding your sled???
shawnj
My BOP gasket arrived. Tempted to drain the oil yet again to get the job out of the way seeing there is no snow in sight for a while. Any tricks for removing oil (it’s new oil) without having to buy another drain plug o-ring? Was thinking about using a vacuum tool but not sure if I’d get it all out.
shawnj
I do have the bypass btwWithout the ROV bypass done it will blow out even faster.. Maybe onto your right foot while riding your sled???
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
If the ring is new? Flip it over and reuse.. Just don't over torque the sh*^ out of it.. I have used them numerous times without using a new one.. Also the torque on that BOP gasket is INCH POUNDS i believe.. Follow the torque specs and get the correct torque wrench if you don't have one..My BOP gasket arrived. Tempted to drain the oil yet again to get the job out of the way seeing there is no snow in sight for a while. Any tricks for removing oil (it’s new oil) without having to buy another drain plug o-ring? Was thinking about using a vacuum tool but not sure if I’d get it all out.
sideshowBob
I have changed my oil numerous times and just reused the the oil drain gasket....so far no problem
shawnj
Ya o-ring only been installed once and to torque spec. Funny the original started leaking and I never ever removed it. Only after I put new oil it did it leak lol. Thanks for the heads up on the BOP torque. I will look them up again on his site. I do have a nice little torque wrench for these smaller bolts, i used it for the chaincase bolts.If the ring is new? Flip it over and reuse.. Just don't over torque the sh*^ out of it.. I have used them numerous times without using a new one.. Also the torque on that BOP gasket is INCH POUNDS i believe.. Follow the torque specs and get the correct torque wrench if you don't have one..
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
pretty sure Travis has a video on BOP web site in this gasket and torque.Ya o-ring only been installed once and to torque spec. Funny the original started leaking and I never ever removed it. Only after I put new oil it did it leak lol. Thanks for the heads up on the BOP torque. I will look them up again on his site. I do have a nice little torque wrench for these smaller bolts, i used it for the chaincase bolts.
shawnj
Yes I believe your are right.pretty sure Travis has a video on BOP web site in this gasket and torque.
SnoWarrior
- Jan 13, 2005
- Long Island, NY
- 2024 Sidewinder L-TX LE
Or you could install this, then you never have to replace the o-ring.
Site sponsor
EZ Drain Oil Drain
Site sponsor
shawnj
I definitely gave some serious thought into one of them. One day perhaps.Or you could install this, then you never have to replace the o-ring.
EZ Drain Oil Drain
Site sponsor
Turboflash
- Mar 18, 2019
- Southern MN
There's a few of these kits around.
PEFI also has one. Like all their hardware, it's like jewelry.
EASY OIL CHANGE - 998
No more mess and wasted time when changing your 998T motor oil Here is the Easy Oil Change, entirely designed and developed in our facility, that reflects the quality, efficiency and longevity of Precision EFI products. Made from CNC aluminum, the Easy Oil Change allows to drain motor oil...
precisionefi.com
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Went to dealer today and they said Yamaha has a rubber gasket now. Any one hear that Yamaha is now selling a rubber gasket like bop for oil tank?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
No, fake news, they are still using silicone, but at least they are using a good amount of it unlike in the past.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
ok thank you, getting ready to do barn of parts gasket. Any tips I need to know besides follow his instructions.No, fake news, they are still using silicone, but at least they are using a good amount of it unlike in the past.
shawnj
Kept putting off the BOP gasket install. Decided to just tackle it today and get it out of the way. I was surprised how much moisture/condensation was on the upper inside tank housing. I cleaned and wiped it all out well before reassembling. Old gasket material came off easily. Made sure to get it all of each surface. Used blue Loctite on the threads. Torqued to 6 foot pounds in increments. Checked few mins later and re torqued. Dealer said they put a wrap of teflon on drain bolt threads. I also trying this. Not sure if it will deteriorate with the oil or not but o-ring pretty new and only been off once. Hopefully this will stop the little drops of oil I’ve been finding on bottom of tank every couple days.
