fx10mtx
Great bushings, fits great and more durable.
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
Can they be ordered anywhere in Canada?
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
Thanks!
enticeraised
RX1MPete said:Can they be ordered anywhere in Canadx2a?
x2
Zakre
enticeraised said:RX1MPete said:Can they be ordered anywhere in Canadx2a?
x2
Sled Werx has them , Spenc is a great guy to deal with! Got min in on friday mucho tight now! Did my lower balljoints too, must be a new sled !
Rooster828
- Feb 24, 2019
- Minnesota
- 2008 Yamaha phazer
Well I must be retarded. I’m trying to put this kit in the upper arms of my phazer and they are too tight plain and simple Are you guys leaving the rod inside and putting the bushing on or are putting them on the arm then pounding the rod through ?
i use a threaded rod with 2 large washers to pull them in when i install them. i do take a file and make sure there is a decent champher on the arm to make them easyer to install.
Snorunner
- Jul 17, 2018
- Deerwood
- 2016 Vector XTX
2017 Vector XTX
2001 Arctic Cat
Put some lubricant or oil on the outside of the bushings and the inside of the control arms as well. Should make them easier to press in. The advice of the long threaded rod you are getting is a method of pressing. Good advice!
Rooster828
- Feb 24, 2019
- Minnesota
The lowers I could press in with a vice. I will try this technique for the upper even though I busted two of the bushing collarsi use a threaded rod with 2 large washers to pull them in when i install them. i do take a file and make sure there is a decent champher on the arm to make them easyer to install.
Hooray!
- Aug 12, 2017
- Maine USA
- 2009 Yamaha FX Nytro XTX
1998 Yamaha VMAX 700 XTC
Installed mine w a few sockets selected for the right size. Easy install, grease them a little too.
Hooray!
- Aug 12, 2017
- Maine USA
Dr. FeeLGooD
I pressed mine in with rubber jaws on my vice. Not good. This sealed the ends and squeezed oil out of the oil lites. Need to leave a space as to not seal them tight. Spindle bushings from the Bushman are a huge improvement also.
Hooray!
- Aug 12, 2017
- Maine USA
I called them prior to installation and confirmed greasing them up was fine, as shown in the pics, greased up, lined up on the bottom, turned a-arm over and tapped a wood block with a hammer to seat the other side... worked well. Not sure what you mean with squeezed out the oil as I thought it was a copper metal matrix vs. actual "oil" impregnated...I pressed mine in with rubber jaws on my vice. Not good. This sealed the ends and squeezed oil out of the oil lites. Need to leave a space as to not seal them tight. Spindle bushings from the Bushman are a huge improvement also.
Dr. FeeLGooD
The metal is infused with oil. Lots of it.
