Ridge line
- Nov 19, 2019
- Cape Breton
- Yamaha Phazer
anyone out there have a fix for darting , just got my FX 121 out and it’s really darting bad . Any advice out there would be appreciated
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
I use dual carbides and really like Snow Studs' Double Down. Some don't like the push in corners but I've been OK with that as I don't speed through corners.
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
Shimming the skis and installing Stud Boy Shaper bars solved my darting.
Ridge line
- Nov 19, 2019
- Cape Breton
- Yamaha Phazer
Where do you shim , to widen stance ?Shimming the skis and installing Stud Boy Shaper bars solved my darting.
yam429
- Jan 18, 2009
- Saint Michael, MN
- 2009 Nytro XTX, 2010 Vector LTX, 1981 SRX 440, 1989 Inviter, 1991 Snosport, 2004 Snowhawk
- Saint Michael
Snowtrackers.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Align your skis to 1/8 toe out.
Replace bushings if the front end is loose.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
1/4" toe out (set toe out with a weak bungee cord between the loops) , reduce the rear torsion spring, ski savers from Bergstrom (reduces how far your wearbars dig in, and protect your ski).
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
I tried almost everything that has been mentioned here to solve the darting issue with my son's Phazer. And I'm a big fan of doing whatever possible with stock parts to get a sled to handle and perform the way the rider likes. Whereas some of these things did help, it didn't completely solve the issue. So for us, it was time to go beyond stock. We installed a set of Polaris Pro Steer skis with Slim Jim Dooly runners. For us, that was the 100% solution to the darting. But yet the steering is still positive and light.
MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
X2 Exactly what I did tooShimming the skis and installing Stud Boy Shaper bars solved my darting.
Ridge line
- Nov 19, 2019
- Cape Breton
- Yamaha Phazer
Are the stud boy runners duel runners and wha length carbide is on them .X2 Exactly what I did too
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
Stud boy shapers are not dual runners. The stud boy Deuce bars and Woody's dooleys are as well as slimjim dooleys. All of the above will reduce darting. But shimming and pulling that front limiter strap made a dramatic difference with Dooleys. Alignment is critical as well. The last bit, is getting a steering slop kit, as they do loosen up in the front end.
The length of carbide is always in relation to the lug height and studding out back. If only running 1- 1.5" with no studs, you may need only up to 6". If studded, you may have to go to 8" And that varies if you are running a solo bar, or dooley.
Good luck!
Good luck!
Creeksider
- Nov 16, 2014
- Kemptville Ont.
- 2010 Yamaha Phazer
The following was done and cured 95% of darting, wondering and Yamaslop symptoms on a groomed trail.
- Yamaha OEM bearing "fix" part# SMA-BEARI-NG-KT
- All A arm bushings replaced with Oilite parts
- Ski bolt bushings and collars replaced
- Steering block replaced with a billet part with Oilite insert.
- New outer tie rods
- 6in. Slim Jim Doolys for carbides
Front limiting strap is in the stock position.
