grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
All three phases should output the same voltage. Measure the resistances between the white wires (3 combinations). 15.3 volts is to high for a regulated output. Somethings not right.
Garry Smith
- Mar 25, 2019
- Fort Frances
- 2007 Phazer GT
Thanks Guys ; changed out stator = it was burnt around the wire connections ! Now I've got a code 12 crank position sensor . I changed complete unit with new sensor & rectifier/regulator ! What could the problem be ? After a lot of checking & testing I found that the NEW crank shaft sensor was 2 mm too far away from the stator ! Put the old one back in & it fired right up ! BEWARE of the aftermarket parts = they don't seem to be built to exacting standards !
Have you turned the engine over yet?Thanks Guys ; changed out stator = it was burnt around the wire connections ! Now I've got a code 12 crank position sensor . I changed complete unit with new sensor & rectifier/regulator ! What could the problem be ?
Garry Smith
- Mar 25, 2019
- Fort Frances
- 2007 Phazer GT
Yes ! No fire !Have you turned the engine over yet?
aftermarket stator? some times the wires are in the wrong place for the pick-up coil.
Garry Smith
- Mar 25, 2019
- Fort Frances
- 2007 Phazer GT
Yes = after market . Will try switching wires .aftermarket stator? some times the wires are in the wrong place for the pick-up coil.
Garry Smith
- Mar 25, 2019
- Fort Frances
- 2007 Phazer GT
Switched wires = code gone but still no fire !Yes = after market . Will try switching wires .
might need to clean and dry theplugs now as they might be full of gas from the failed starts. oil does not smell like gas?
Garry Smith
- Mar 25, 2019
- Fort Frances
- 2007 Phazer GT
Plugs are dry = no gas smell ; no spark . Switched wires back & forth on crank sensor = no spark & code 12 now showing ?might need to clean and dry theplugs now as they might be full of gas from the failed starts. oil does not smell like gas?
better take an ohm meter to it and check if it is in spec.might have gotten a bad one.
Garry Smith
- Mar 25, 2019
- Fort Frances
- 2007 Phazer GT
I've got 200 ohms on new one & 197 on old one .
so it should be working. you are hearing the fuel pump run before you try and start it?
