MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
Noticed after a long ride with a lot of WOT runs that the clutch side cover gets very warm.
Anyone vent this panel with a frogzskinz or something? I am always surprised at the amount of belt dust in there and I am sure the heat does not help.
Suggestions?
Suggestions?
UP bushman
A cool belt is a happy long lasting belt and here ya go.
http://www.frogzskin.com/index.php?main ... cts_id=152
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
greenthumb
Not trying to hijack, but I was wondering if others are having trouble with hot phazer clutches.
Granted I have a turbo, but both my clutches get hot enough that you can barely touch them. I have blown two belts this season, while my other non turbo sled has almost 4k on its factory belt.
Cubby
- Dec 14, 2009
I check my clutches regularly and they never get hot. A little warm but that's all. When you say you are running the factory belt - the updated one or the old one??
MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
Cubby which size vent did you out on the backside of the clutch cover? Also do you think the 4" circle would fit on the side?
Oh & PS-where did you get them. Not sure I want the full blown Phazer kit, looks excessive
rtx15
Cubby
- Dec 14, 2009
You can put either a 3" circle or a 3" x 5" rectangle on the back. I don't think a 4" would fit. I bought the 3" circles for $15 for a pair and the 3 x 5 rectangle was $15 as well. Frogzskins also sells specific Phazer kits for the clutch side, englne side, and top kit. They are very pricy.
rocklong
I put three on my clutchs I had left over from air box mod. I put one on the side of primary and secondary and 1 on upper front of primary. Seem to work well there has to be a lot of engine heat in there.
