MikeWalters
Noticed after a long ride with a lot of WOT runs that the clutch side cover gets very warm.
Anyone vent this panel with a frogzskinz or something? I am always surprised at the amount of belt dust in there and I am sure the heat does not help.
Suggestions?
Suggestions?
UP bushman
A cool belt is a happy long lasting belt and here ya go.
http://www.frogzskin.com/index.php?main ... cts_id=152
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
greenthumb
Not trying to hijack, but I was wondering if others are having trouble with hot phazer clutches.
Granted I have a turbo, but both my clutches get hot enough that you can barely touch them. I have blown two belts this season, while my other non turbo sled has almost 4k on its factory belt.
Cubby
- Dec 14, 2009
I check my clutches regularly and they never get hot. A little warm but that's all. When you say you are running the factory belt - the updated one or the old one??
MikeWalters
Cubby which size vent did you out on the backside of the clutch cover? Also do you think the 4" circle would fit on the side?
Oh & PS-where did you get them. Not sure I want the full blown Phazer kit, looks excessive
rtx15
Cubby
- Dec 14, 2009
You can put either a 3" circle or a 3" x 5" rectangle on the back. I don't think a 4" would fit. I bought the 3" circles for $15 for a pair and the 3 x 5 rectangle was $15 as well. Frogzskins also sells specific Phazer kits for the clutch side, englne side, and top kit. They are very pricy.
rocklong
I put three on my clutchs I had left over from air box mod. I put one on the side of primary and secondary and 1 on upper front of primary. Seem to work well there has to be a lot of engine heat in there.
