BongoNation
- Jan 21, 2018
- Terrace BC
- 2007 Phazer FX
I have a 2007 phazer fx that is saying er1, er2, when its starts and the check engine light is on. The temp lights is staying red too. Im new to this sled so im wondering if anyone has any ideas. Ive looked up codes and cant find anything under err11. The sled seems to run fine still although Ive been scared to actually ride it until this is sorted out. Thanks in advance.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
You'll find those codes here:
https://ty4stroke.com/attachments/fault-codes-jpg.77941/
When my son's Phazer had an intermittent er1, it was caused by a bad ground connector at the battery. Cut out that connector and just soldered that wire together. Could be related to your other starting issue.
BongoNation
- Jan 21, 2018
- Terrace BC
- 2007 Phazer FX
Great, thanks a lot . Thats what I was looking for. Ill check that out.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Also check connectors at the ECU. Check for water or corrosion.
- 12K
