Boondockerbrad
- Nov 5, 2017
- Edgar wi
- 2007 yamaha phazer mtx mtn lite
Yes healthy blue spark and i deemed it as fouled cuz it would misfire and had no power wen u hit the throttle bogged really bad took plugs out one looks fine the other was burnt and caked blackIs it a healthy Blue Spark?
Lets get to basics then. Do you have compression tester?Yes healthy blue spark and i deemed it as fouled cuz it would misfire and had no power wen u hit the throttle bogged really bad took plugs out one looks fine the other was burnt and caked black
Boondockerbrad
- Nov 5, 2017
- Edgar wi
Yes but my compression tester wont reach down into the cylindersLets get to basics then. Do you have compression tester?
If your thumb is big enough or use hand. Seal it off. Crank it over. If it blows hand/thumb off thats close enough. You positive there is no code?Yes but my compression tester wont reach down into the cylinders
Boondockerbrad
- Nov 5, 2017
- Edgar wi
No codes popping up on the clusterIf your thumb is big enough or use hand. Seal it off. Crank it over. If it blows hand/thumb off thats close enough. You positive there is no code?
Well you have spark.You eliminated fuel with the Ether. Lets assume you have valve timing. If you have compression and proper spark timing it will run.
Boondockerbrad
- Nov 5, 2017
- Edgar wi
Ok i have good compression on both cylinders and theres pressure pushing out the exhaust as well wen crankingIf your thumb is big enough or use hand. Seal it off. Crank it over. If it blows hand/thumb off thats close enough. You positive there is no code?
Try another set of plugs/Ether and then if no go its got to be Pickup. Try testing it. Specs are in that link I posted. First post.
Here:
Crankshaft position sensor resistance:
189 ~ 231 Ω at 20 °C (68 °F)
(Gray – Black)
(Gray – Black)
Alberta Farmer
- Dec 26, 2016
- West Central Alberta
- 2015 Phazer MTX
Might have mine figured out. Put battery charger on and it started right away. Doesn't really explain why it would start at 20 below and cold engine, but not warmer with a warm engine though. Had tried bat charger right away, but didn't realize charger wasn't working ( 2 of them quit at once no less)Does it crank when it doesn’t start?Electrical. Very time consuming to track down. Grounds are first place to look. Other would be fuel pump relay. Is it red one?
That’s cool! I trust no charger except the hum from my old Schumaker.Might have mine figured out. Put battery charger on and it started right away. Doesn't really explain why it would start at 20 below and cold engine, but not warmer with a warm engine though. Had tried bat charger right away, but didn't realize charger wasn't working ( 2 of them quit at once no less)
Dfisch
- Nov 17, 2014
- Yamaha Phazer
yea, I was going to say if my battery sits for 2 months and the temp dips 50 deg like I just did in iowa then my ride wont start unless I put a fresh charge on it. It doesn't matter if I run it a couple times a month during the off season either. something about the temp drop is enough to pull the angry pixies from the battery and wont allow enough of them to flow for a cold start.
You must watch Ave! Guy is awesome.yea, I was going to say if my battery sits for 2 months and the temp dips 50 deg like I just did in iowa then my ride wont start unless I put a fresh charge on it. It doesn't matter if I run it a couple times a month during the off season either. something about the temp drop is enough to pull the angry pixies from the battery and wont allow enough of them to flow for a cold start.
Dfisch
- Nov 17, 2014
- Yamaha Phazer
bumble fu$%, angry pixies, let the smoke out, treat especia'l, etc. are all phrases I have incorporated into my daily lingo b/c I watch WAAAY to much AVE. lol Canadians crack me up.
