phaz4
SIMONS CPR said:the phazer has alot of throttle response and it pulls hard right from the start, it has plenty of torque. i am very impressed with the stock phazer, it is already running close to 12's in the 1/4 mile at 91+ mph and we have only had it to the track three times so far. jeff
what is the speedo indicated speed at 91mph?
BBM
- Oct 6, 2004
How does the 1/4 mile time of the Phazer compare to the Apex? Or any other sled.
monker
A stock apex should run mid 10s, vector probably right around 11.
There is a stock (clutched) F5 at the track here that runs in the 12s.
BV1
Umm...
A stock Phazer runs 12's? at 91 MPH?? They go 91 MPH?
If so Im in shock, and impressed!
-Steve
-Steve
stock speedo reads approx 94mph at 91 radar mph. rx-1 best fully tweaked run with stock susp was 10.82 @ 118 mph apex best fully tweaked run with stock suspension was 10.55 @121 mph vector best fully tweaked run with stock susp was 11.76 at 107mph (i think).... this is only our second trip to the track with a bone stock phazer and STOCK ride height. when we lower this sled and do all the tricks the other sleds had it should be a 12 sec sled at 93+ mph. not bad for a little 500 twin four stroke. jeff
![](/styles/admin.gif)
![](/styles/vip.gif)
Great info Jeff
...Great Job!!
![Div20 ;)! ;)!](/styles/default/xenforo/smilies/div20.gif)
BV1
SIMONS CPR said:stock speedo reads approx 94mph at 91 radar mph. rx-1 best fully tweaked run with stock susp was 10.82 @ 118 mph apex best fully tweaked run with stock suspension was 10.55 @121 mph vector best fully tweaked run with stock susp was 11.76 at 107mph (i think).... this is only our second trip to the track with a bone stock phazer and STOCK ride height. when we lower this sled and do all the tricks the other sleds had it should be a 12 sec sled at 93+ mph. not bad for a little 500 twin four stroke. jeff
Nice, very impressed!
-Steve
i guess on pavement you get the maximum traction so you will go faster than on snow. that phazer is not a production unit so is it possible that its faster than the ones were gonna get this fall. ![4strokes :4STroke: :4STroke:](/styles/default/xenforo/smilies/4strokes.gif)
PureBlue
Simons CPR, do you have any pictures of the Phazer on the track.
