ammojim
Battery is fully charged, pump cycles when the key is turned on, but nothing when I turn the key.
It makes almost a high pitched tone when I turn the key.
Not sure if this matters, but my reverse has been not working intermittently.
YukonMP
- Dec 25, 2014
- Yukon Territory
Welcome to TY, nothing like a sled that won't start to turn a lurker into a member. Glad you are on board.
I think I'd try jumping the terminals on the solenoid/starter.
ammojim
Ok help me out here, where exactly are those located.Welcome to TY, nothing like a sled that won't start to turn a lurker into a member. Glad you are on board.
I have an issue with it not starting when it's extremely cold, but the motor turns over. I've read it's a relay issue, but now the motor won't even turn over.
(I'm not the most mechanical guy, FYI
YukonMP
- Dec 25, 2014
- Yukon Territory
Sorry, I don't have a Phazer so I can't be precise. I did just Google 'Yamaha Phaser starter solenoid' and a bunch of images came up that will give you and idea. It is pretty distinctive and usually pretty exposed, I'd bet right side. If you are uncertain there will be other more experienced guys chiming in.
Your cold start issues are another can of worms. Let's start with what year the sled is and have the updates been done.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
It is located just in front of the main fuse box, big red wire from the battery connected to it. Pull the rubber covers away from the two large terminals. Using a tool, jump between the two terminals (might make a big spark). Starter should crank the engine. Make sure you have a fully charged battery. Try a booster pack. If the starter won't spin and just a whine, it's likely the starter. I've had that before.
2stroken
What year is it?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
His info says 2008.
ammojim
2008 Phazer FXWhat year is it?
Now I'm getting a click from the side of the motor when I turn the key.
Bad relay?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Have you tried jumping the terminals on the starter relay/solenoid as suggested?
Northbound
Experienced the same issue last year and it was the solenoid. Easy and cheap to replace once you know it's the issue.
ammojim
Jumped the starter relay, no good.Experienced the same issue last year and it was the solenoid. Easy and cheap to replace once you know it's the issue.
Could be the starter I guess.....
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
As long as the battery is good and all the connections as well, sorry to say it sure sounds like it's the starter. You can get it out easier if you cut off the tab protruding from the bottom of the engine that prevents the starter from coming out the bottom. It's completely useless.
