Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
Here is the story. 07 GT with all the updates including cold start and grounding block. I had into my Yamaha mechanic in November for new plugs and replace coolant. I also put in a new Yuasa battery. New preminum fuel in the tank. That was a month ago. I went to start it today for the first time and it just cranks and cranks but never catches. I tried the trick to prime the injectors and same thing - just cranks.
I can hear the fuel pump turn on and I have updated the relay for it.
The rpms when cranking are over 300. The sled is stored in my garage but its been -25C all week here.
What should I be checking?
I'm hoping to find someone with a heated garage to put it in for a few hours and see what happens.
Thanks all!
Thanks all!
turbogts22
- Jan 16, 2021
- Spooner, Wisconsin
- Two 2010 Phazer GT's
Have you tried a shot of starting fluid in the throttle bodies?
Cubby
- Dec 14, 2009
Not yet - I dont have any. I will try to pick some up tomorrow.
Cubby
- Dec 14, 2009
OK got it going. I did 2 things:
1. Even though I charged the battery on the sled yesterday I brought it inside and changed it when it was warm. It took longer to fully charge.
2. Drained and refilled the tank with premium.
It started right up!
