Monster Max
Just wondering if anyone has a picture comparing the float bowls. Trying to see if this 03 I bought has been done. Last year it was cutting out on the hills if I went up slow, just fine at full throttle.
Frostbite
The new float bowls are just deeper. You'd almost have to look at two sleds to tell the difference. I sold my stock float bowls so I am not in a position to measure the difference for you, sorry.
Even if you have the stock bowl I think its www.thunderproducts.com that have longer main jets that you can use that do pretty much the same thing. They are pretty cheap too.
Good luck
Frosty
Good luck
Frosty
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
Does the 04 have updated bowls or was it the 03's that just needed them?
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
- '03 RX-1 Mountain LE
RX1MPete said:Does the 04 have updated bowls or was it the 03's that just needed them?
The '03s got the update to '04 float bowls.
lancef53
Monster Max
Perfect, Thats what I needed to see! Thanks alot.
Monster Max
Ok, I confirmed that I have the updated bowls. However last winter it would die on inclines if I wasn't full throttle. When they change the bowls, is there any change to the float height?
Monster Max
one more thing. I heard the kit came with new main jet holders. I assume they are longer. Any info on these?
The jet holders are longer and they are o-ring sealed into the bowl. Big improvment. ===SRXSRULE===
Blue shadow
Would the new jet holders fit in the 2003 old float bowls and do the same trick ?
lancef53
I installed the update kit myself, it is a single part number that comes with the tubes and bowls. I can't believe you would have the new bowls and not the tubes.
If you don't have the update, contact a dealer and have them get you the kit. I couldn't get the kit from my dealer, they said they didn't know anything about it. I got it from a guy on Snowest that worked at a dealer in Iowa, or somewhere near there. All I paidwas the shipping to me.
If you need the part number, I can get it, I noticed the old bowl that I took the picture of was in the bag with the part #.
younggun
- Jan 9, 2006
this weekend we were out on a hill on my dads rx1 and it would kind of gurgle when it got to 9000 rpms and then if you let off the throttle it would be fine then if you got it back up to 9000 rpms it would gurgle out whats the problem also how many rpms should this sled pull on climbs
KbxSrx
10,250 to 10,500 younggun
- 9K
