Hi
First...sorry I got this in the wrong group...I meant to put it in Engine, but I had multiple windows open and managed to send the post to the wrong one. Anyway...I should have specified that my riding is "performance trail", running fairly hard on a regular basis. The motor is most likely going to need to be ringed at minimum, due to my oil usage issue, and I don't really want to bump the compression...I just haven't found many options for pistons. As I said, the only things Wiseco offers are stock bore in 13:1, 1mm overbore in 12:1, and 10:1 turbo pistons. I don't want a turbo, and I don't want to have to bore unless I'm forced to, so that leaves 13:1 or pistons from the dealer...and I'm trying to avoid dealer parts, since they are the reason my sled started burning oil with under 1000 miles. Now at around 5,000, I use twice as much oil as my two stroke buddies. For the cams, I'm not really that interested, just trying to get ideas since the engine will be apart anyway. And if I have to use the 13:1 pistons, they will most likely require cams to work efficiently anyway.
Jim
