byoffcr
Tork said:http://www.ty4stroke.com/privmsg.php?mode=post&u=142
Yeah, reading this thread, I PMed Allen yesterday. Didnt even ask what they were. Just told him when he has them, send them to me.![]()
I got mine through a auto store for about $4.00 a plug less than from yamaha dealer.
vice108
Srxspec said:1 heat range colder and a dual electrode plug. The only downfall is they don't come with the threaded caps needed for the Apex plug boot. I should have sets available later this week.
Allen - I'm assuming you've seen good results with these on the dyno. Is there any down side to using them, and can we just use the threaded caps from our original plugs? Also - do you need to gap them or just leave them as is from the box?
vice108
byoffcr
vice108
[/quote]
They seem to be a little harder starting with this plug..
vice108
[/quote]They seem to be a little harder starting with this plug..
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
As Terry said, they are a little bit harder starting. See a 2-3hp improvement throughout the HP curve over stock. The stock Apex plugs have a solid tip which isn't threaded on so you would have to find some old plugs that have the thread on tip to use if you buy them on your own.
I will have sets of 4 available for $32 shipped in the lower 48 states and they will ready to install when you receive them.
byoffcr
Srxspec said:As Terry said, they are a little bit harder starting. See a 2-3hp improvement throughout the HP curve over stock. The stock Apex plugs have a solid tip which isn't threaded on so you would have to find some old plugs that have the thread on tip to use if you buy them on your own.
Thats a good price. I think the dealers are at $10.00 a plug.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Terry, the cheapest price I could find online was $6.23 per plug and that was before any shipping charges. You would still have to go through the work of finding a set of screw on caps for the plugs as well.
zipclean
What company makes these plugs?
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Allen would they be worth installing on a modded sled,say w/hauck pipe fuel excellerator and 3 dehree advance timing key,or do you think i would need better than 90 octane to run them w/best results,and who is dynoray??Srxspec said:As Terry said, they are a little bit harder starting. See a 2-3hp improvement throughout the HP curve over stock. The stock Apex plugs have a solid tip which isn't threaded on so you would have to find some old plugs that have the thread on tip to use if you buy them on your own.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Pete, I would see no reason you couldn't add them to your sled as well.
zipclean
O.K. NGK
BA APEX
so the plug is: cr 10 ek ?
vice108
Sounds like a good deal Allen. As always - thanks for lending us your expertise.
byoffcr
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Yep, NGK CR10EKBA APEX said:so the plug is: cr 10 ek ?
I found them last year at an Advance Auto for just under $5.00 a plug US.
byoffcr
MightyWarrior said:Yep, NGK CR10EKBA APEX said:so the plug is: cr 10 ek ?
MW are you running them?
