NFLD-Nytro
I've seen a few posts about this, so I figured seeing as I have a couple of Polaris wheels in my tickle truck I'd try it out. But the bearings are smaller on the Polaris and won't bolt on to the Yamaha mounts. What are you guys doing to make them fit?
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
NFLD-Nytro said:I've seen a few posts about this, so I figured seeing as I have a couple of Polaris wheels in my tickle truck I'd try it out. But the bearings are smaller on the Polaris and won't bolt on to the Yamaha mounts. What are you guys doing to make them fit?
http://www.ty4stroke.com/viewtopic.php? ... eel+skidoo
Also do a search for rockerdan, he has a great DIY for this.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
This is Rocker Dan's info, more than just idler wheels.
http://www.ty4stroke.com/viewtopic.php?t=78847
09nytro
I'm useing the older wheel out of the polaris ( out of the x 12 no mods just bolt on ) they got the 6205 bearings in them
NFLD-Nytro
Do you mean out of the 2012's?09nytro said:I'm useing the older wheel out of the polaris ( out of the x 12 no mods just bolt on ) they got the 6205 bearings in them
I did the "rockerdan" wheel mod on my Attak.
I used 6 'doo mounts and 6 Poo wheels. 1200 miles on the sliders and they look great. No cracks in the rails. I also install the small wheel kit up front too.
09nytro
No like back in 97 with the extra 12 i use to ride polaris and have parts off them they are 25mm id and 135mmNFLD-Nytro said:Do you mean out of the 2012's?09nytro said:I'm useing the older wheel out of the polaris ( out of the x 12 no mods just bolt on ) they got the 6205 bearings in them
sgilbert
arent those wider bearings? requires modifacation to mount shoulder to center wheel between cogs. correct?09nytro said:No like back in 97 with the extra 12 i use to ride polaris and have parts off them they are 25mm id and 135mmNFLD-Nytro said:Do you mean out of the 2012's?09nytro said:I'm useing the older wheel out of the polaris ( out of the x 12 no mods just bolt on ) they got the 6205 bearings in them
NFLD-Nytro
sgilbert said:arent those wider bearings? requires modifacation to mount shoulder to center wheel between cogs. correct?09nytro said:No like back in 97 with the extra 12 i use to ride polaris and have parts off them they are 25mm id and 135mmNFLD-Nytro said:Do you mean out of the 2012's?09nytro said:I'm useing the older wheel out of the polaris ( out of the x 12 no mods just bolt on ) they got the 6205 bearings in them
I just picked two up at the Polaris/Yamaha dealer here in town. The bearing numbers are the same. I'll try and get them mounted up later this evening.
09nytro
No they will mount right up ,you can get them though marshall for 25.00 bucks
sgilbert
thats probably the new excell wheels with 6005 bearing. I also have cases of polaris wheels, so, would be tempted to modify
Vincenthdfan
- Nov 28, 2009
- Olympia, Washington
- 2006 Apex MTX
I put Polaris wheels inside and out on my Apex MTX.
I used Polaris mounts outside the rails, bolt right on.
On the inners I had my machinist buddy mill a couple thousandths off the spacers on both sides on the inside the rails.
The fit is perfect and the wear to my hyfax is pretty well eliminated (although also I use ice scratchers to add additional cooling on iced trails).
Do it! Its a very worthwhile mod.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
I used Polaris wheels on my 05 Warrior on the pro action suspension. No problem with the install!
09nytro
yeah the bearing in them are the same as the excell wheels
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
No they're not. They are 6205 and the Excell X wheels are 600509nytro said:yeah the bearing in them are the same as the excell wheels
