09nytro
If you look up the bearing #'s they are the same but two diff. companys , but the bearings are the some , you are right the #'s are diff.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
The 6005's are actually 3mm thinner than the 6205's. The axle diameter is the same but the thickness of the bearings are different. I've calipered them and that's why I went with the Excell wheels. That meant there was no 3mm overhang on the collar. Some guys run them with the slight overhang but the price of the Excells was the same as a Kimpex $29.00. So I didn't think twice about it. I like precision. Call me ANAL!09nytro said:If you look up the bearing #'s they are the same but two diff. companys , but the bearings are the some , you are right the #'s are diff.
09nytro
What was the thickness on the 6005's
canoehead
- Jan 14, 2011
- NE, Alberta
13mm. That's also how much I cut out of my rear axle to install my 4th wheel. 6205's are 16mm.
NFLD-Nytro
I put two on today. Bolted right on.
09nytro
6205's are 15mm and i put these wheels on a rtx se too maybe thats way they fit
