kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
That makes for a bad day!
Lashcat
NO joy! Fresh gas and I put a little in each cylinder.
I do not have a fuel pressure test kit. I will have to borrow one and test that next week.
The Crank position sensor tested good.
Lashcat
The fuel pressure is spot on. I replaced the coil pack that seemed a little weak. No joy.
I am at a loss.. without seeing it and hearing it .. I am about out of help.
Lashcat
Well it is looking like a blown head gasket. Could be a burnt valve also. I will not know until I pill the head.
That sucks but happens.. I would consider a thicker head gasket as long as it has to be changed.
Lashcat
Aftermarket head gasket or OEM?
I added a Cometic from Ulmer, thicker to drop compression and to make it safer on pump gas.
- 13K
